I want to generate report using citadel sql server, i,am using excel for report viewing. I have written a Visual Basic code for fetching data from srq to excel. The problem is when i fetch all the fields from sql it generate report, but when i gave a single variable name like
Mycomputername/process/pot1@value it give a error column:Mycomputer not exsist.
Given below is the code wriiten to get the value.Please suggest ASAP
'****** GET HEPTANE RECORDS ******
Sub GetHEPTANERecords(ByVal rNumber As Integer, ByVal dDate As Date, ByVal sTime As Date, ByVal eTime As Date)
Dim ReadHEPTANE As ADODB.Recordset
Set ReadHEPTANE = GetConnection.Execute("SELECT TRANSTECH34/SRS/LVL_GALL_TK1 FROM IntData WHERE [LOCALTIME] BETWEEN '" &
sTime & "' AND '" & eTime & "'")
Thanks & regards
Mantosh
