Lookout
Revision number extraction from tortoise SVN
I am using TORTOISE SVN(version 1.8.8)
I am explaining below clearly about my expectation...
For example:Current revision numbers of FILE1-1184, FILE2-1184 and FILE3-1184..
after sometime we will modify some files and recommitt and get revision numbers like FILE1-1191, FILE2-1192, FILE3-1184.
There may be chance of adding new file also naming as FILE4:1192..
I just want to extract the name of the files here (FILE1, FILE2, FILE3 and FILE4)and their latest revision numbers(1192,1192,1184 AND 1192) from SVN to excel or word document.
Is there any method to copy this revision numbers and file names automatically into anyother format like word document, .xls or .txt ?
Kindly help on this.Thanks in advance.
Regards
Govindarajan G
(4,782 Views)
Your question had nothing to do with Lookout or any other NI software. Why have you posted here instead of some svn forum?
(4,775 Views)
