Lookout
SQLExec ODBC Column:table_x.Pwr_T not found
Okay,  That worked for me.  Thanks!
Now...
I need advise on setting up dynamic (programmatic) LocalTime values for the queries.  Basically, I want to do Math_Avg queries for different intervals but always starting from current time going back by the interval amount.  I can do this with expressions and math but I'm having trouble and it looks like I can only insert static sort of code in the query like Text Entry.
Ideas on what types of objects I can use and the syntax I need to pass this equivalent logic to SQL?:  LocalTime <= Now() AND LocalTIme > Now() - Interval
Ed
Message 11 of 15
(3,218 Views)
Basically the idea is to calculate the time in numeric, and convert the result to text in SQL.
For example,
use expression to calculate the time for Now()-interval, like
expression = now(trigger) - 00:00:01
The interval can be in just numeric, like 0.00004
And then, write this code in SQL
LocalTime > ' "&text((expression), "mm/dd/yyyy hh:mm:ss")" '
Is this what you want?
Ryan Shi
Message 12 of 15
(3,215 Views)
My vesion of your statement:
gives Error: Unexpected character: "
Here is my exact substitute on LocalTime contraints after working statement with static times:
LocalTime > ' "&text((Exp_Sql1), "mm/dd/yyyy hh:mm:ss")" '
I tried other combos of parenthesis but no luck.
Ed
Message 13 of 15
(3,210 Views)
Got it...
Just needed ending &....
works great.  Thanks!
Message 14 of 15
(3,206 Views)
yes, I miss a &
it should like
'"&text(...)&"'
Ryan Shi
Message 15 of 15
(3,203 Views)
