Lookout
Set time on AB PLC using Lookout 5.1
Using Lookout 5.1, how do you set the time on a AB ControlLogix PLC using RSLogix 5000? The controllogix PLC needs an integer so that it can be set using the PLC's "SetSystemValue" (SSV) function. How do you convert the time format given in Lookout 5.1 to integers to be used by the AB PLC?
Jacob
Message 1 of 1
(3,416 Views)
