Lookout
Sharing data between an existing application and a new application.
An existing Lookout application communicates with Texas Instruments PLC's via the Lookout Tiway driver. I am adding a new application that will communicate with Texas Instruments PLC's via ethernet cards manufactured by Control Technologies Incorporated. The two Lookout applications have to share data. Is there some way to "bridge" the Tiway network to an ethernet network?
(3,328 Views)
Do those two processes run on the same pc? If yes, you can directly share the data between them.
If no, I think you need to connect the two pc via ethernet.
Ryan Shi
(3,308 Views)
