Lookout
Slave to slave communications
I need to pass data between slaves on a DF1 half duplex network, how can I do this using the master (PC running lookout 6.6) to relay the data? Thanks
(4,811 Views)
Create a driver for each slave and connect the appropriate data points for one to connect to the other. Connect I:0_0 in slave one to O:0_0 in slave 2. That will transmit the input from slave 1 to the output on slave 2.
Brian T. Kinard
President - SCADA and Security Division
2110 Nance Street
Newberry, SC 29108
(4,491 Views)
