Lookout
Spreadsheet Logger - Naming Data Fields
I need to name the data fieds specifically in my spreadsheets. Unfortunatly the neames default to the full path of the object whose data I am storing the spreadsheet.
How can I change the data field name to custom text that I specify?
NoElephant
(4,223 Views)
There is no direct way to change the spreadsheet column labels in the Lookout Spreadsheet object. However, one work around is to create a named expression which points to the data member to be logged (in relative mode). Then log the expression (named in the desired manner) using the spreadsheet object.
Chad Pelletier
(4,223 Views)
Elephanty,
I guess the easiest way would be to create a Expression Object and log the expression with the name you want instead of a connection.
That's the only way I can think of for now.
Regards
Roli
(4,223 Views)
