Lookout
Standalone 6.5 to Server - Client
We have a version of Lookout 6.5 running as a standalone system on one PC.
We would like to add another PC/Lookout to run as a client.
Can this be done with 6.5?
Will we need to get another license?
Is there a conversion process or will the current Lookout process work as-is in a client/server arrangement?
Thanks for your time.
Kevin
(3,395 Views)
You would need a Client License for the Lookout client.
Development depends on a few things, but would need to be developed indepently.  You could save your server process, then reconnect the driver connections to symbolic links that connect to the server.
Forshock - Consult.Develop.Solve.
(3,370 Views)
