Lookout
Table object storing all data with same time
I have a data table I'm trying to use for all data viewing/storage. When viewing the data in MAX, it's showing every entry as having the same timestamp. If I log data directly from the RTU instead then the logging works fine. I'm using Lookout 6.1. Thanks in advance for any help.
Message 1 of 25
(7,551 Views)
Can you make a sample to show how you use the datatable for data viewing and storage?
I give a changing value to a datatable cell, and log that cell, it works fine.
Ryan Shi
Message 2 of 25
(7,538 Views)
Let's say I have an RTU called AquatrolTank, and a data member AquatrolTank.Level. If I were to turn the logging of that point on, it would correctly show a trend and MAX data, but I keep the logging off there.
Then I have a datatable called water, and a member Water.TankLevel. I have the connection Water.TankLevel= AquatrolTank.Level; in the .lks. It's logging changes as well, but they all end up with the same time stamp.
I've done this in other projects and it worked fine; perhaps I'm either missing something silly here or there's a quirk from 5.x to 6.x that brought this about?
Message 3 of 25
(7,532 Views)
What if you use hypertrend in lookout to monitor the datatable trend?
Does the trend keep going?
Ryan Shi
Message 4 of 25
(7,520 Views)
The trend shows a flatline except for that one time, where it shows a "vertical anomaly" presumably having all the data points MAX was showing.
Message 5 of 25
(7,516 Views)
I tested loading the .lks in 5.1 and the trends worked fine coming from the table. This appears to be a 6.1 issue. Any thoughts?
Message 6 of 25
(7,442 Views)
Could you upload your process file to ftp://ftp.ni.com/incoming
I want to set up the same application to reproduce the problem so that I won't miss anything.
Ryan Shi
Message 7 of 25
(7,421 Views)
Uploaded as spole.l4p. Thanks very much for looking.
Message 8 of 25
(7,400 Views)
Edit: FTP giving me errors, I'll upload it tomorrow.
Message 9 of 25
(7,397 Views)
K shuld be up there, spole.l4p and lks.
Message 10 of 25
(7,376 Views)
