Lookout
TestStand Errorlogging
I'm making an errorlogging in TestStand by adding the StationPostStepRuntimeError in the StationCallbacks.seq. Everytime there is an error it will call this callback, however I can't find the property containing the error message and code. Does anybody know how or where I can find this property?
Thanks in advance,
Mark
Mark Vorage
Vision Engineer
Philips Technologie GmbH
View Mark Vorage's profile on LinkedIn
(3,345 Views)
Hello Mark,
You may want to post your question under TestStand section of this forum for a faster response. This particular section is for the Lookout HMI/SCADA package from NI.
Khalid
(3,345 Views)
Mark,
You can access the error that caused the StationPostStepRuntimeError callback to be executed by using the lookup strings "Parameters.Step.Result.Error.Code" and "Parameters.Step.Result.Error.Msg". The Station Callbacks all receive a Step container with the information from the calling step as a parameter. You can use the "Parameters.Step" to access information about the calling step.
Feel free to let us know about any other questions. As Khalid said, it is usually better to post in the TestStand section of the Discussion Forums.
Shannon R.
(3,345 Views)
