Lookout
This process will not run on a client version of lookout?
I get the following error message when I try to upload my process for web
access: "This process will not run on a client version of lookout?"
Why am I getting this?
Tommy Scharmann
(3,568 Views)
Hello Tommy,
You're probably trying to upload a process which has a Driver object in it
(like Modbus, AB, etc.) As you are aware, Lookout Clients (and Web CLients)
do not have Driver Objects and that's the reason you're getting the message.
You will normally upload your Client process -- a process which doesn't have
driver objects but talks to a Server Process in turn.
Khalid
"Thomas Scharmann" wrote:
I get the following error message when I try to upload my process for web>access:
Tommy Scharmann
(3,568 Views)
You are correct. I found a TIWAY object shortly after I posted the message.
I must have accidently created the new object.
Thanks for you help.
Tommy Scharmann
(3,568 Views)
