Lookout
Timeofmonth spreedsheet trouble
Hi all
I got this problem with spreadsheet in lk6.1.
I've created spreadsheet which logs values to csv, normally.
I need to log these values only at the last day of month, or last hour at current month, only once.
I tried using timeofmonth timer so that I could use "Log Now" option in spreadsheet but it won't work.
Example:
Log now = if(Timer1<=00:00:59,ON,OFF)
Timer1 is timeofmonth countdown, 'till 00:00:00 ?
Is there option to check LastDayOfMonth or something like this, so I can trigger this logging on??
(5,580 Views)
The Timer1 is not the countdown value. It is ON or OFF of the timer.
So, if you set Log Now = Timer1, it will log at the end of the month. But I'm not sure if the timestamp will be the end of the month or the begin of next month.
Ryan Shi
(5,555 Views)
Hi Ryan
I've tried that.. but it trigerrs logging and creats csv for next month..
Is there any option inside LK6.1 that can check last-day-of-month so that I can trigger one-time loging?
(5,542 Views)
