Lookout
Trends in Lookout 5.1
I have zero experiance in Lookout and I have been tasked with modifying an existing Lookout 5.1 application. The old systems had several analog values coming into the SCADA via opto22 modules. I have replaced those with Online TAGS in RSLinx. I can display the analog values in a numeric display but I don’t know how to add them to the existing trends. Can you explain this to me?
(4,727 Views)
I have worked with Lookout for quite a bit in factory and foundry applications over the last two decades.
I will try to help.
When you are in front of your PC and logged in with editing permisions; feel free to give me a call and I'll do my best to walk you thru it.
        Mark
Mark Edward Baldwin
PRESIDENT
PROTEC Inc.
mark@protecelectric.com
765-668-8888
1-800- 225-3946
765-668-8882: fax
(4,214 Views)
