Lookout
Upgrade issues for Lookout v3.8 to 6
I am going to upgrading Lookout from version 3.8 on a stand alone win 98 pc, to Lookout 6, a client / server enviroment, hopefully using win 2003. Are there any particular hardware requirements, and will Lookout 6 run on Win 2003 server?
Any other notes of interest, for my upgrade would be appreciated.
(3,860 Views)
Hi there: Currently National Instruments does not support Lookout on any server Operating Systems. The knowledgebase below refers to Windows 2000 Server. However the same applies to Windows 2003 Server. http://digital.ni.com/public.nsf/websearch/8D564A39D6D649AA86256DF9006C85B2?OpenDocument Other than the correct system requirements You can also refer to page 5 of the document linked below for instructions on upgrading from 3.8 to 6.0. I would strongly recommend that you back up all your database files and process files on to a CD before you do the upgrade since it is a big jump. You do not need any additional hardware. The system requirements of your computer are also listed in the document linked below on page 3. Lookout Release Notes: http://www.ni.com/pdf/manuals/371384a.pdf Let me know if you need any additional help. Jaideep J.
(3,842 Views)
Although NI does not "SUPPORT" installations on Windows Server systems, I know for a fact that it does work.  We have run Lookout 4.0 ~ 6.0 on server systems.  The lack of "SUPPORT" comes from NI not doing any testing on Windows Server OS.  We have run 4.0/4.5/5.1 on Windows NT Server 4.0. and have been running Lookout 5.1 on Windows Server 2000 and 2003, and Lookout 6.0 on a Windows 2000 Server.  Be careful if you do install on these systems though, as NI will tend to use that as a reason for any problems you may have (so far we have not had any problems that were due to the Operating System), and you may have trouble when getting technical support on issues..
(3,840 Views)
Yes you are right to some extent. We have had customers report that the installation of Lookout on server OS have been successful however, NI did not design Lookout to work with Server OSs and hence can not guarantee that it will work. On the flip side there have been customers who were unsuccessful with the installation as well.
(3,834 Views)
I agree with what others have said thus far, and although NI never throws in support for servers, so far I have never had an issue with Lookout running on NT 4.0 Server, Windows 2000 Server, or Windows 2003 Server Standard Edition.
There are some major consideration to get your new Lookout up and running.  Please read and compare the Lookout Developers Manual for your new and old versions to study some of these issues.  A little planning will go a long way.
The 3.8 method of efficient remote data retrieval was through DDE and not TCP/IP.  DDE was much more efficient for low bandwidth (or even high bandwidth for that matter).  Hypertrends with DDE links on remote clients in 3.8 stored their own database to display the trends, so you could not maintain a contigious history without running the client all the time.  DDE had its issues when clients outside local subnets were necessary, so TCP/IP had to be the future.  All new hypertrends use URL's for their link and Symlinks provide a two-click change of addresses for an entire process of object links, instead of changing each individual object link.
I had to revamp all my processes to get things running smoothly.  The advantage with the new Hypertrend/Symlink combo is that the data display is always from the server citadel database so you have contigious history available at the client.  They have improved some early performance issues with hypertrend updates and screen writing, but I would not expect to run hypertrends with constanly changing data on a dialup line....broadband only.  If you run multiple traces in remote machine hypertrend objects/displays, I would NOT upgrade to Lookout 6.0 at this time.  Lookout 5.1 is much better for this.  I think Lookout 6 and the new citadel have several months of grin-and-bear-it development and bug fixing before it is worthy of its calling.
Notice major changes in server/client process ideal configuration and programming methods.  The way the clients should be developed has totally changed since Lookout 3.8.  Save all your lookout 3.8 stuff including lookout.ini, lookout.sec etc.  You will have to import your security files and convert to new versions which now get stored in system32 directory of windows.  They get overwritten along with lookout.ini if you reinstall or repair the newer versions so make backups anytime you mess with the installer.  Start with a clean install and one at a time, import your old .lks files and recompile.  Then save all.  Now you can go through the new .lks files and clean up issues.  You will have to do some major search and replaces on the old client .lks to work well with new server processes.  The server processes will need work too, because you will be deleting all the graphic objects and eliminating any user interface.  Only the clients processes which link to the server for their displays, should need graphics and user interface.
Running out of time..that's all for now..
Cheers,
Ed
Message Edited by erblock on 08-24-2005 05:35 PM
(3,828 Views)
