Lookout
Using Lookout as the HMI to monitor the 3rd control device
Due to the 3rd control device does not provide OPC driver , but just provide TCP/IP communication API , I'd like to know if can use Lookout to create the TCP connection with the device ?
David
(3,057 Views)
Yes, using the IPASCII Object, assuming the API is simple enough.
-Khalid
PS:  And if the API is a little involved, and you have the resources (especially fluent with C++), you can use the Object Developer's Toolkit and develop your own CBX (i.e., driver Object) for this device.
Message Edited by Khalid on 11-23-2005 10:52 AM
(3,053 Views)
