Lookout
Using $System Data Members over a Network
I wish to use $System Data member of a Lookout field installation over a process control ethernet LAN to indicate "System Status" on a Lookout Process (in Control Room).While I can see $System data members in the local machine,I cannot over a network.However I can see the local Lookout process file(and its data members) in the remote Lookout installation on the same network.Is there a work around?
(3,042 Views)
Thanks.Subsequently I found answer to my question.
(3,042 Views)
