Lookout
Using a Twido in Lookout
Just wondering if anyone has found out how to use a Twido in Lookout using some other driver that support ethernet.
We are using TWDLCAE40DRF.. and we are just trying to find away to controll it trhough lookout not really wanting to have to
stick another plc in place. Any info appreciate thanks
(3,879 Views)
i think if you are on ethernet you want to use modbus TCPIP and point to the TWIDO   via the IP address you have on the TWIDO
if you want to use the primary serial port you need to use a RS-485 to RS-232 adapter and use the MODBUS RTU protocol and set the
TWIDO to have that protocol turned on for port # 1.
I know this works since I am using 6 twidos over RS485 into one HMI touchscreen on MODBUS SERIAL.
(3,779 Views)
