Lookout
Using pots why can't you have a fraction decimal for value i.e.. 1.5 rounds to 2???
When creating pots why can't a decimal be entered for a value i.e.. 1.5 you can define the range i.e.. 1-30 but you cannot enter a decimal value without being rounded up to a whole number???
Message 1 of 11
(6,518 Views)
Check the 'resolution' setting.  If you want values to tenths change it from 1 to 0.1.
Message 2 of 11
(6,513 Views)
thank you changed the resolution but it doesnt work still it will act like it will take the new value but reverts back
Message 3 of 11
(6,506 Views)
Check the numeric format of the display.  It might be set to '0' (generic or 0.0 will show tenths).
Message 4 of 11
(6,503 Views)
tried that one too im using it as a high reservoir alarm pot if my reseroir goes over 31.5 then it over fills but my options at this point are 32 or 31
Message 5 of 11
(6,501 Views)
would it be in the latters why i can only manipulate the level between whole numbers???
Message 6 of 11
(6,499 Views)
Check if the pot is remotely connected to another object that may not have the same resolution.
Forshock - Consult.Develop.Solve.
Message 7 of 11
(6,483 Views)
its not i am running an allen bradley plc 500 with rockwell latter logic software and using lookout as the object oriented programming im thinking that i have to go into the latters binary codes and manipulate the coding so it allows for decimal values i have two reservoirs that i have different addresses that i can controll one i can set to tenths the other is the problem that i am having
Message 8 of 11
(6,480 Views)
If the register can use a floating point the decimal would work.  Otherwise the you can program an "implied decimal" on the PLC.
Message 9 of 11
(6,478 Views)
im assuming thats what i have to do is go into the plc programming and tell it can use decimals instead of whole numbers the reservoir i am referring about was reprogrammed and supervised by another operator and thus theres a lot of things im finding that are wrong and or safety protocols were taken out of the programming itself
Message 10 of 11
(6,475 Views)
