Lookout
Ver 4.0.1 Different screen resolution won't allow all of control panels to be displayed.
I've got a customer with version 4.0.1 of Lookout. When the software and application are installed on a back-up computer with lower screen resolution not all of the screen is visible, and I can't scroll to see the right and bottom edges. Is there something I'm missing?
Marty C
(3,671 Views)
Lookout uses the same resolution that it is programmed with. I always use the same resolution monitor on both the master and remote computers. Never tried it but you may be able to reprogram your remote process using a lower screen resolution. Probably easier to just get a new monitor though.
Brian T. Kinard
President - SCADA and Security Division
2110 Nance Street
Newberry, SC 29108
(3,622 Views)
Lookout appears to automatically use initialization settings (ini file settings) first from the same subdirectory as an "autolaunched" process, then (if no ini file found there) Lookout uses the Lookout.ini file settings from the Lookout default directory.
In other words...If you are migrating a process from one platform to another you may wish NOT to import the ini file settings TO the same destination subdirectory as that process.  You may therefore wish to run Lookout.exe first (then close all open processes) and then OPEN the process name INSTEAD of double-clicking on the process name in the Windows explorer (file manager) window (using windows autolaunch feature).
(3,490 Views)
