Lookout
Version 3.8 Freeze
I have found similar problem to earlier post in that computer locks up.
Believe that it happened when:
1. logged in at high security level
2. in EDIT mode
3. timed out
Always 1 & 2 were true but not 100% sure about 3, but problem seemed to
go away after increasing my security time to 4 hours.
Sent via Deja.com http://www.deja.com/
Before you buy.
(4,412 Views)
Add to this
4. When you are using OPC and you prevent access to other programs by setting
system security ratings.
John
(4,412 Views)
"John Dunlop" wrote:
>>Add to this >4. When you are using OPC and you prevent access to other
programs by setting>system security ratings.>>John
This is fixed in Ver 4.0. You will need the following entry in your lookout.ini:
[Security]
DisableWindows=0
Khalid
(4,412 Views)
We were experiencing a similar problem usually if we did a lot of editing.
We fixed by defining lookout.exe and tbd.exe as "real time" under NT. We
have gone from almost daily lockups to none.
(4,412 Views)
