Lookout
View 2 Processes at same time with Lookout 6.1 Web Player
In IE7 I am trying to view two process files at the same time. I have a tab for one process and a tab for the other, but I can only view one at a time. If I am looking at the process file that is on "tab 1" then all I get is a white screen on "tab 2". If I refresh "tab 2" then the process file under this tab opens and the process file on "tab 1" goes to a white screen.
Is there a way to view both files at the same time?
Jason Phillips
(6,240 Views)
I see the same behaviour. I guess you cannot. As Lookout can only run one instance, Lookout player also allows one instance running. So, if you refresh one, you see another stopped.
Ryan Shi
(6,229 Views)
Ok. It would be nice if this functionality were possible in the next release.
Thanks!
Jason Phillips
(6,226 Views)
