Lookout
Want a single entry for alarms in the "AlarmsWindow"
I am not sure it is possible to show a single entry in the alarms window for 1 alarm. What we can do however, is use a push button to acknowledge all alarms at once. We can set the value of the Alarm.ack data member equal to the push button. However, this will acknowledge all your alarms. You can set it to where the push button acknowledges all alarms in a particular area but you can not get it to where it is alarm specific.
Jaideep
Message 11 of 12
(1,378 Views)
Actually, I wanted to show a single entry for ALL alarms.  I just cited that one alarm as an example.  Sorry if that caused some confusion.
So given that I want to do it for all alarms, will those lookout.ini settings work?  Did you have success with those settings afterall, Dimension Finder?
Thanks in advance.
Message 12 of 12
(1,379 Views)
