Lookout
Were are the "error logs" saved to?
Were are the "error Logs" saved to.  My Lookout 6.0 system crashed last night for no appearent reason, other than the building A/C unit went out and the room became very hot.  The PC that is running Lookout was still operating and the call-out system running on it notified me that Lookout was down.  I started the system back up with no problems.
(2,991 Views)
The only place where you can see what happen would be in the Event Viewer from your Windows computer.  Go to Control Panel, Administrative Tools, and you will see in there the Event Viewers.  Hope this helps
Ricardo
(2,984 Views)
