Lookout
What does Modbus excpetion response 2 (Illegal data address) - function code 1 (start=800, count=410) mean?
I replaced a Control Microsystems Scada PLC with an Allen Bradley Micrologix 1400.  It communicates via a Modbus modem with kenwood radios to the host computer.  The host computer running Lookout has a serial connection to the modbus modem.  I did not change anything on the lookout software but this is the message that I got.
Do I need to delete the configured points and re-create them with the new addresses?
What does “start=” and “count =” mean?
Do I need to change anything in the Advance Modbus Options for the maximum values to work with an Micrologix 1400?
(19,182 Views)
The slave likely doesn't support the range of bits requested.
See
http://www.simplymodbus.ca/exceptions.htm
Bob
(19,175 Views)
