Lookout
What is the MS Access syntax for the ODBC Data Transforms
I'm able to query Citadel data in MS Access, but I'm not able to use the Data Transforms (Min, Max, Avg, etc..) in the criteria or SQL statement. What is the exact syntax for these data transforms? Within brackets, quotes?
John T. Sampson
(3,077 Views)
Start web browser, type www.ni.com/support, search KnowledgeBase KB Search with keywords 'lookout' and 'transform'. The second entry should be "How Do I Use Data Transform with MS Access and the Citadel ODBC Interface?" KB ID:1CDGLG9C.
Did you find it?
Hope this helps
Roland
(3,077 Views)
