Lookout
Why can't I run code developed in Lookout 6.2 in Lookout 6.5?
Our customer has developed code in Lookout 6.2. Now they have bought Lookout Run Time 6.5 and they are unable to run their code. Is there any limitation which could cause this kind of behaviour?
Thanks...
(6,419 Views)
Accepted by topic author MilosR
They should be able to run the .lks file.
The .l4p file is not compatible.
What's the error they got?
Ryan Shi
(6,413 Views)
Hi Ryan,
You're right. They are able to run .lks file but not .l4p file. There is no error, they are just unable to run .l4p file, and since you say that .l4p is not compatible than i guess it is expected behaviour...
Thanks for your help.
(6,406 Views)
