Lookout
Why is lkcitdl.exe installed when installing Lookout 6.1
I just installed Lookout 6.1 on a brand new machine and noticed that lkcitdl.exe was installed.
If lkctidl.exe is not needed by Lookout 6.1 then why is it installed when installing Lookout 6.1?
Jason Phillips
(6,403 Views)
If you have old database created by Lookout 5, you need lkctidl.exe. For example, if you want to convert the database from 4 to 5, you need first to create the citadel 4 database, that's why lkcitdl.exe is installed.
Maybe there are some other reasons.
Ryan Shi
(6,396 Views)
Thanks!
Jason Phillips
(6,385 Views)
