Lookout
Writing Variables to mySQL DB
Can anyone explain to me how I can write the data from variables into a mySQL Database table?  I have a SQLExec object created and can use the object to manually write text values to my table, but I am unsure of the syntax to use to write the actual values from an alias I have tied back to a Modbus register.  The Modbus object is named Modbus1 and the alias is tied to a scaled decimal value and is named test.  Here is an example of the SQL statement I am using:
"INSERT INTO testtable (Name, Age) VALUES('sam', Modbus1.test)"
These are simply test values and have no real use for my actual program, but if I can get these working I will be able to complete my program.  Here is the error I receive when executing the SQL statement:
[Not Buffered] S0022/1054: [MySQL][ODBC 3.51 Driver][mysqld-5.0.37-community-nt]Uknown column 'Modbus1.test' in 'field list'.
Any assitance or direction you can offer me in getting the values of my variable to write to the table would be appreciated.
(5,645 Views)
The following link may help:
http://digital.ni.com/public.nsf/allkb/4ADEEA04CD24AE0B862565E20002A16F
If the MySQL table and ODBC driver are setup correctly the SQLExec object will use the same SQL syntax.
(5,643 Views)
Thank you for your input.  This allowed me to write the values to the db as I hoped.  Where is the text() function coming from?  Is it native to Lookout or to mySQL?
(5,640 Views)
The text function is a native Lookout function.  You can find more information about this function and other Lookout functions in the Lookout Help.
(5,637 Views)
I tried using the sqlexec function and it doesn't work. Can somebody tell me how this actually works from beginning to end. I want to send data to mysql database. Thanks.
Robert
(4,673 Views)
Here is the lookout source file based this issue:
(4,652 Views)
Robert, please post in your thread:   http://forums.ni.com/ni/board/message?board.id=190&thread.id=7348
Mike
Forshock - Consult.Develop.Solve.
(4,650 Views)
