Lookout
aggregate
Hi, folks
Theres a question for you.
I use floating panels for make simple instruments to display information everywhere in the project.
These instruments are identcal except for the information displayed. I make o project for the instrument, and I use aggregates object in the main process for generate the instruments .I'd want to define up to 30 instruments. In this way I can reduce the main project. All works fine, but when I load the main process, its loading speed are very very slow (10s without one aggregate object, more than 2min with it). Why?
I try to use it in lookout 6.1 and 6.5.
I attach the process of the instruments. May you verify if there's something wrong?
Mario Fanelli
Message 1 of 1
(5,823 Views)
