Lookout
any plan to support 21 CFR part 11?
If NI didn't support 21CFR part 11, I must change to another scada program.
Do you have any plan to support 21CFR part 11?
(3,250 Views)
The following link might be helpful to you: http://zone.ni.com/devzone/conceptd.nsf/webmain/EBEE1EF8B8111F2786256C0E00552DF2?opendocument The same goes for Lookout. While it is not by itself compliant with 21 CFR Part 11 standards, it is a design tool that can be used to create an application that is 21 CFR Part 11 compliant. I hope that helps. Let me know if you have more questions. Jaideep J Applications Engineer National Instruments Corp.
(3,232 Views)
