Lookout
can I process more than 1000 I/Os for data logging?
My process requires 1000 digital input for data logging and 500 digital output for HMI display.
Can I use Lookout for this application?
(3,218 Views)
The I/O count is well within the capabilities of Lookout. If you are working with this size of an application you should look into the features of Lookout 5.0. There are means to backup your data from a different computer. Also view and export your data easily from the new Historical Data Viewer. There has always been means for redundancy. Going through a course manual also helps, class or self paced.
(3,218 Views)
