Lookout
can PCI-DIO-32HS act as GPIO???
hello:
as title....i wish i can capture data at this sampling clock and output pattern at next sampling clock.....even then....i wish those action can be assigned on different pin within a port....can my PCI-DIO-32HS do it???and how??
thank you for your help in advance.......
Best Regards
(2,919 Views)
Hi Alvin,
This particular section of the Forum is specifically for discussing issues pertaining to the Lookout HMI/SCADA software.
I doubt there will be many readers here with the DAQ knowledge required to answer your query. So, you may want to re-post your query under Measurement Hardware.
Good luck.
Khalid 🙂
(2,919 Views)
