Lookout
clear Chart programatically/ Labview
Hello everybody,
When I connect a Chart with the counter-variable "i" inside a While-loop, the first point I see in the Chart is (0,1) instead of (0,0).
If the Chart is outside the While-loop the Chart misses no points.
Can anyone please explain this behaviour ? Hoy can can solve this problem ?
Cesar
(3,517 Views)
Cesar,
The first point should be (0,0).  Try to expand the axes scales so you can see the points more clearly.  You can also try probing the wires and run in execution-highlight mode.
If you're still seeing the first point as (0,1), then post your sample VI so we can take a look.
-Khalid
PS:  For LabVIEW specific questions, you may want to post in the LabVIEW forum.. for better 'n faster responses.
(3,511 Views)
