Lookout
clear database
For our lookout process i see the sql icon at the bottom right corner of the screen. I also see that Citadel is installed. Do i need both of these running?
Is there a way to empty the database so we can start logging data after the database has been cleared?
(3,948 Views)
Lookout 6+ uses SQL (MSDE and SQL Server Express).  Citadel is required as well.
There are no functions to clear the database in lookout.
Mike Crabtree - Lead Developer
Destek of Nevada, Inc. / Digital Telemetry Systems, Inc.
(866) 964-6948 / (760) 247-9512
(3,940 Views)
You can manually clear the database. In MAX, you can create a new database, and let Lookout log data to the new one. Then detach/delete the old one.
Ryan Shi
(3,929 Views)
