Lookout
finding broken client/server data links
Is there some way to get a list of what data links don't have a current data source?
I mean, I have a server process, which has a bunch of data tags.  I also have a client that uses those tags.  I think I may have some data items in the client that are not linked to a data source on the server.  Now don't think I can just 'look' through the pages, I've got way to many tags and internal items to do that.  Is there a utility of another way to check that all the data links are sourced by something valid?
David
(3,394 Views)
Hi David,
I don't think there's such a utility.  And as you probably know, the LKS file won't be of much help either, unless in situations where you already had links to a different server and wanted to change these links to a new server.  In which case we could do a search-n-replace.
-Khalid
(3,384 Views)
