Lookout
help/contents doesn't always display when using Vista
On a fresh startup of Lookout 6.1 on Vista, the help/contents always starts as expected.  At a later time and for some unknown reason, the help/contents may not display.  Is this a know problem and what is the solution?
Joe C.
(6,737 Views)
It's an unknown issue. Are you using Vista SP1?
You can find lookout.chm in lookout folder. Try to directly open this file.
Ryan Shi
(6,728 Views)
Ryan,
Yes, we are using Vista SP1.  I have confirmed that when the help/contents selection doesn't work that opening the .chm directly as you suggested does work okay.
Joe C.
(6,684 Views)
