Lookout
horizontal lines in trends
The time that is used for the time stamp changes causing horizontal lines in the trends and problems in the spread sheet. What causes the time to change and what clock is it sync with the PC time is not changing that is running lookout
Message 1 of 11
(6,910 Views)
I am having a hard time understanding the questions/problem.
Forshock - Consult.Develop.Solve.
Message 2 of 11
(6,888 Views)
The problem we are having is when data is logged to the spead sheet the time in lookout is changing this cause the datalog time stamp to be out of oreder and we are seeing horazontal lines on our trends. See Image
Message 3 of 11
(6,875 Views)
This is what the spreadsheet looks like
8/24/2012 0:05
8/24/2012 0:25
8/24/2012 0:45
8/24/2012 0:04
8/24/2012 1:05
8/24/2012 0:24
8/24/2012 1:25
8/24/2012 0:44
Message 4 of 11
(6,874 Views)
I had a similar issue a few years back with an AMD dual/quad core machine.
What is it running on?
Message 5 of 11
(6,859 Views)
Lookout is running on a virtual server the processor on the physical server is a Intel Xeon E5540 @ 2.53GHz 2 processors this is a bit
Message 6 of 11
(6,845 Views)
I have a similar system for testing using a Xeon on VMWare and have not experienced this issue.
Is there a Time Server set it in Lookout?  (Options > Time Synchronization)
Message 7 of 11
(6,842 Views)
We are using Time Synchronization if I turn that service off after lookout starts the problem goes away. If I go to option the Time Synchronization option is grayed out is this because I don't have the proper login to view this option or does my software license not have this option.
Message 8 of 11
(6,838 Views)
Is there an entry in the time servers?
Message 9 of 11
(6,834 Views)
How to I check this I don't have a development license
Message 10 of 11
(6,827 Views)
