Lookout
how I can stop Lookout?
I need stop(shutdown) lookout for Date and Time.
(2,961 Views)
You can shutdown Lookout by executing lookout.exe with the -shutdown parameter. You can do this within LK using the RUN object.
For example:
C:\Program Files\National Instruments\Lookout\lookout.exe -shutdown
There are more details on the KnowledgeBase article, "Is there a way to shutdown Lookout programmatically?"
(2,961 Views)
