Lookout
how can I enlarge my process windows automatically after I download a webclient control and why my second html process cannot be view correctly (the page is blank) after I download the webclient control?
How can I enlarge my html process windows automatically
after I download a webclient control and why my second html process cannot be view correctly(the page is blank) after I download a webclient control. I'm using Win98 SE and running Lookout 4.0.1 build 51. Has anyone have an idea. Thank You.
(3,091 Views)
Maybe you can connect a TRUE to the panel.maximize datamember. This would maximize the panel object when you load it.
If this is not what you mean, you could maybe attache those two sample process files and explain more in detail what is your intention.
Hope this helps
Roland
(3,091 Views)
Rudin,
I see that Roland has already answered your first question so I will be answering the second one since I am the one that suggested that you use the MetaRefreshUpdate html command in previous post. It actually doesn't work with two process files unless you press the refresh button and redownload the process.
So the other way to go about it is to create a modified version of the server process that will rotate the panels and export this process for the webclient.
I created a sample process file that does that, with three panels that rotate every 30 seconds, using a sequencer object (please see attachment). I tested it on the webclient and it works fine.
Cyril Bouton
Cyril Bouton
Active LabVIEW Developper
(3,091 Views)
