Lookout
how do I acces opc item properties in Lookout
I'm trying to view timestamps for different opc items
(3,738 Views)
If you enable the datamember of the OPCClient object for logging to database, then the timestamps will be stored. You can then use a sqlexec object to retrieve the data and timestamp you desire.
Michael Shasteen
Applications Engineering
www.ni.com/ask
1-866-ASK-MY-NI
(3,738 Views)
Enabling a datamember for looging, it will log that data with the system timestamp, not with the true timestamp (date of the aquisition). If i view data in a hyper trend i see data versus system date. All I am interested is if I can recreate a citadel with old data and timestamps in Lookout.
(3,738 Views)
As I understand OPCLabview is OPC2.0 compliant. Is there a way in Lookout to access opc item properties, such as timestamp? (In Lookout I connect to OPCLabview, vi-based server)
(3,738 Views)
Lookout is a OPC 2.0-compliant server and OPC 1.0-compliant client. You will not be able to access that time stamp in Lookout. Our LabVIEW DSC SW, on the other hand, is 2.0-compliant both as a server and a client.
(3,738 Views)
