Lookout
how to create an alarm file
We would like to have a file showing all daily alarms past and current (like an excel file) that we would be able to read the alarms and also print them out as needed.  We would also like a push button on Lookout that we could press as a shortcut to this file without exiting Lookout.
MWarner
(6,032 Views)
Accepted by topic author mwarner
I would suggest using the NI ActiveX controls available with Lookout.  Support many parameters to view only what you want. Other than that,use SQL to request them from the citadel database.
Good luck,
Mike
Mike Crabtree - Lead Developer
Destek of Nevada, Inc. / Digital Telemetry Systems, Inc.
(866) 964-6948 / (760) 247-9512
(6,030 Views)
Hi Mike,
I was just wondering if you could explain how to set up the active x control and how I would create a push button to open the file.
Mike Warner
MWarner
(6,015 Views)
