Lookout
hypertrend lenght change with button or numric entry
I would like to change the "trendwith" with a push button or enter a numric value in to "trend.with".
When I try this I receive a message that "the remote posistion is not witable".
Versions 6.0.1 and 6.0.2.  Non networked systems.
Message 1 of 8
(7,326 Views)
Use Pot instead of pushbutton or TextEntry.
Ryan Shi
Message 2 of 8
(7,305 Views)
I tried numric entry with a pot to "trend.with". This is when I get the message that "the remote posistion is not witable".
Message 3 of 8
(7,298 Views)
I retried the numric entry with a pot and it works. Not sure what I did wrong the first time.
But having some operators doing this will be hard for them.
I tried to use buttons but not getting them to work.  I have  included an expression that I hope to use.
Pb_24H 24 hour button
Pb_12H 12 Hour button
PB_6H     6 Hour button
HyperTrend1.trendWidth=if(Pb_24H,1,if(Pb_12H,.5,if(Pb_6H,.25,HyperTrend1.trendWidth)))
Thanks in advance
Message 4 of 8
(7,296 Views)
I create a sample using your expression.
Let me know if it works correctly.
Ryan Shi
Message 5 of 8
(7,279 Views)
Accepted by topic author mwjenn
Only process1.lks file in zip folder.
Need process1.lp4 to run.
Message 6 of 8
(7,252 Views)
You can open the lks with lookout, lks is the "script" that builds the l4p.
Mike Crabtree - Lead Developer
Destek of Nevada, Inc. / Digital Telemetry Systems, Inc.
(866) 964-6948 / (760) 247-9512
Message 7 of 8
(7,244 Views)
Thanks Mike.  I never opened the app like that before but I figured it out.
Message 8 of 8
(7,239 Views)
