Lookout
image navigator
I am trying to use a custom graphic from the image navigator in an expression in the Lookout 6.0.2 program, but when I use this graphic and convert it to a WMF, Lookout returns an error "Graphics Directory Does Not Exit!".  The graphic I am modifying is the T-Intersection pipe that is located in the NI Pipes folder that is accessed with the image navigator.  I have rotated this particular pipe 270 degrees and shaded it with a turquoise fill color.  I have used the straight Pipe and Elbow pipes from this folder and altered them then converted them to WMF with no problem.  Any assistance with this problem or a work around would be appreciated.  Thanks.  Werner
Werner Knight
(3,643 Views)
I got the same error. It seems that something wrong with "T intersection".
How about use "Tee_L.wmf" instead?  Insert->Graphic->Pipes->Tee_L.wmf
Ryan Shi
(3,636 Views)
