Lookout
keyboard button "Windows" bypass security
Hi folks,
In an Lookout 6.6 process, I set some operators with different security levels and lock the access to the operating system using the Option>System windows.
The items "User cannot switch to another program", "User cannot exit lookout" and "User cannot open or close process" are set to the level of the maximum user (in my application is 6). When I'm logged with a lower level (operators are level 2), lookout lock the access to the operating system, but if you press the "Windows" button on the keyboard, the windows start menu appears and works.
The same project running in lookout 6.5 works correctly.
There's something to do to avoid this?
Message 1 of 1
(5,596 Views)
