Lookout
logon failed
I am getting the following message when starting lookout 5 and have not been able to correct the problem any suggestions?
logon failed  invalied lookout securety file
(3,654 Views)
Greetings!
  1) Check for administrator privileges.
   http://digital.ni.com/public.nsf/websearch/2A9BF89DADB79B9F86256AE100538BEE?OpenDocument
   2) this error occurs if there is not a Lookout.sec file in the system32 folder. To fix the problem, try uninstalling Lookout and then reinstall the same.
Avi Harjani
(3,635 Views)
Thank you for the reply!
I found the lookout.sec file in the system32 folder and replaced it with a backup file and it took care of the problem.
(3,633 Views)
