Lookout
lookout 6.2 on server 2008 R2
I would like to install Lookout 6.2 on Windows Server 2008 R2, & the version will likely be SBS 2011 Essentials.  Does anyone have negative experience with Lookout running on Windows Server 2008 R2. I understand that SBS 2011 Esstentials being a realitively new release probrably has limited exposure.
My main concerns are realative to scada operations, database stability(long term), stable long term unattended operation(remote, headless), and WebClient accessibility.
(5,498 Views)
According to the release note of Lookout 6.2, it doesn't support Window Server 2008. You might meet some problems, since it hadn't been tested on Window Server 2008.
You might need upgrade your Lookout to Lookout 6.6.
(5,492 Views)
