10-18-2011 07:17 PM
Ouch! Too many hours.
Trying to get lookout to work with Direct logic 205 ethernet. Tried the DLPlus, but have problems. Uninstall, reinstall, etc. Help.
Info:
Dedicated computer for this new lookout 6.5. New computer, but downgraded to xp pro, as I thought that Lookout originally had problems with Windows7. Very much trouble trying to connect to PLCDirects Ethernet modules. Appears to be a DSComm issue.
We just solved an issue with Hypertrend and Allen Bradley Data Points. But now have another problem with Hypertrend not displaying traces.
10-19-2011 02:36 PM
Sorry to be the bearer of bad news, but I called Automation Direct and they told me the DLPlus Drivers are not compatible with Windows 7 and they ARE NOT going to make them compatible with Windows 7. I am going to OPC database for DL communications.
Thanks Automation Direct. ![]()
10-20-2011 09:49 AM
Thanks, Jason.
But this is an XP Pro machine running Lookout 6.5.
10-20-2011 09:52 AM
Did you mean to say that you are going to set up an OPC for DL communications? Is this something I can do with what I have now, or will I need to wait for another driver to be programmed?
What do you mean by, " I am going to OPC database for DL communications." in your previous post?
I appreciate your help.
MK
10-25-2011 02:22 PM
Sorry, I thought it was Windows 7.
For my DirectLogic PLCs that are communicating via ethernet (using DSComm), I purchased the NI OPC Server software to communicate with these PLCs.
