Lookout
lookout and allen bradley micrologix
Does anybody know (or have experience) of connecting Lookout to an A-B Micrologix
1500?
I guess I could use the RSLink OPC server (or even DDE link) as mentioned
in another post, but I know that the 1500 is very similar to the SLC range
so can I use that?
John
(4,359 Views)
"John Dunlop" wrote:
>>Hi,>>Does anybody know (or have experience) of connecting Lookout to an
A-B Micrologix>1500?>>I guess I could use the RSLink OPC server (or even
DDE link) as mentioned>in another post, but I know that the 1500 is very
similar to the SLC range>so can I use that?>>Thanks,>>John
Hi John,
I've used Lookout with Micrologix 1500 and you are correct. We can use the
RSLinx OPC Server to communicate with Lookout Client and actually I wrote
a document that explain how to do that and I'll be glad of sending that to
you if you want. Another option is using PLC5 object in Lookout.
(4,359 Views)
Hi Carlos,
Thanks.
I would love to see that document. Do you know if you can use Linx Lite?
John
"Carlos Barberino" wrote:
>>"John Dunlop" wrote:>>>Hi,>>Does anybody know
(or have experience) of connecting Lookout to an>A-B Micrologix>1500?>>I
guess I could use the RSLink OPC server (or even>DDE link) as mentioned>in
another post, but I know that the 1500 is very>similar to the SLC range>so
can I use that?>>Thanks,>>John>>Hi John,>I've used Lookout with Micrologix
1500 and you are correct. We can use the>RSLinx OPC Server to communicate
with Lookout Client and actually I wrote>a document that explain how to do
that and I'll be glad of sending that to>you if you want. Another option
out.
(4,359 Views)
Hi Carlos,
I realize this is a pretty old post but I would really appreciate seeing that document if you still have it. Could you post it here?
If not and you still have it please send it to longd@ctc.com.
Dave
(3,948 Views)
