Lookout
lookout compiler activex controls error
Lookout v6.5 Unlimited Client, whem Lookout Compiles the file I keep getting errors saying; Class not found: ActiveXControl.  I am using cwbuttons, and the errors are with all of the cw buttons.  Any ideas on how to correct the errors?
MWarner
(5,945 Views)
In Windows\system32 folder, check if the cwui.ocx file is installed. This is for the ActiveX control. If you cannot find it, try to repair lookout.
If it's there, follow this KB to manually register it.
http://support.microsoft.com/kb/146219
What's your OS?
Ryan Shi
(5,938 Views)
xp pro sp2 & 3
MWarner
(5,933 Views)
