Lookout
lookout database capacity
Hello I'm working with Lookout 5.1 and I have some questions about the capacity in lookout database. In a project when the database is near to 2GB, all the SCADA works slower than before. A solution that I found in this forum is to copy and paste in other folder all the data, and it's good... but after I time I need to do it again. I would like to know if the database folder has a limit of almost 2GB or it's more. If there is a configuration to do in Lookout I would apreciatte if give some advices for solving this problem. Thanks FLAVIO CARRILLO SOCIEDAD INDUCONTROL INGENIERA SAC
(6,019 Views)
It depends on the CPU Process Power of the computer. Get and Intel Based CPU computer (Not an AMD), dual core if possible, and give it a try.
You'll see a BIG difference.
Buena Suerte   Smiley Wink
(5,991 Views)
